The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
speedometer does not work
speedometer does not work checked codes had p 0500 (vss bad ) replaced vss still not working (no codes ) replaced instrutment cluster .still not working .replaced engine computer .still not working . replaced connector to vss .still not working . any ideas ?
Have you checked the output gear on the transaxle to see if the gear is damaged or broken. It sounds like it's not spinning the sensor.
Dale Packard crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 247
