2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
MacBookPro 2015 Keyboard backlight connector broken
MacbookPro 2015 Keyboard backlight connector broken while dissembling the logic board ,now it was not power on , please tell keyboard has to change in order to power on.
crwdns2944067:05crwdne2944067:0
Can you please post some pics of your cable and logic board so we can see the damage. Posting the guide picture doesn't help.
it,s broken in to two pieces
OK, still we need to see whats broken so we can guide you to what needs replacing. Do you need a new cable? Do you need a new logic board? Do you need a new keyboard?
@Dan the logic was not working already brought logic board EMC2910, from eBay ,while replacing the logic board the black light connector for keyboard was broken,it it affect the working for mac or working with broken connector.
So you ripped off the cable! Thats not the connector its self.
Sadly time for a new keyboard or uppercase
As you damaged the keyboard cable connection to the keyboard backlight you’ll need to replace the either the keyboard backlight assembly or the uppercase which is a lot easier!
Here’s the guide to get to either MacBook Pro 15" Retina Display Mid 2015 Upper Case Assembly Replacement
New Apple Macbook Pro 15" Retina A1398 Keyboard backlight 2012-- 2015+ Screws - US
Or Macbook Pro Retina 15" A1398 2015 Uppercase with keyboard - US You’ll need to transfer your trackpad over
In either you’ll need a new battery as well! MacBook Pro 15" Retina (Mid 2015) Battery as you’ll damage yours in the process!
crwdns2886500:0Replace a 8800 mAh battery compatible with a MacBook Pro 15" Retina (Mid 2015). 99 Watt Hours (Wh), 11.26 Volts (V.)crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$109.99
i crushed my connector trying to plug it back in after reassembly - has anyone been able to bend back crushed connector terminals?
@owen1234321 - As easy as un-cracking a fresh egg!
Sorry guy you need to replace the damaged parts. How about posting some picks of the damage so we can aim you to whats needed Adding images to an existing question
Rajeev crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 5,276
