Two SSD´S two OS´, only one will boot.
I decided to upgrade my Macbook Pro with an SSD, which improved my overall experience quite a lot! So I wanted to install Windows as well, I went on and bought a second SSD and a caddy to keep everything nice and separated. Then I tried to install Windows, but it wouldn´t let me install Windows from the caddy, so I swapped the disk to the main bay and installed Windows no problem. After the installation finished I swapped the drives back so that MacOS´ disk would be on the main bay, and Windows on the caddy in the secondary SSD. MacOS boots as good as new from the main bay, but Windows takes forever to load but will boot eventually, however, it´s extremely slow, basically unusable. I´ve also discovered that any OS disk I mount into the caddy whether MacOS or Windows is basically unusable due to it taking forever to boot and load anything. Is there a way I can make both run smoothly?
I´ll list the modifications I´ve made to the computer.
  • ADATA SU800 SSD 512GB 6GB/S - MacOS High Sierra.
  • ADATA SU650 SSD 120GB 6GB/S - Windows 10 Home SL.
  • Corsair 8GB RAM + Original RAM 2GB = 10GB RAM
  • Caddy for SSD or HDD.
You are hitting a known issue!
The optical bay SATA port logic on the logic board has a defect so it won’t run at SATA III (6.0 Gb/s) it will only run at SATA II (3.0 Gb/s). So when you put in too fast a drive in the bay (SATA III 6.0 Gb/s) the drive over saturates the port with data.
Think it like trying to tell your deaf grandparent a story… They can only hear the first few words (2) then they can’t hear anything more, they say what?? You repeat your story they manage to get the third word and then they say What! You repeat again this time they get the fourth and fifth before they shoutout WHAT!! And then they just shout down.
Thats about what is happening here! Your system is able to buffer up a few blocks before it get saturated. If the block group is small enough it manages to pass the CRC checksum and get moved into RAM freeing up the buffer for the next group of data blocks. Here we are talking about tens of thousands of blocks!
OK, how to fix? You need to replace the optical bay SSD with a fixed speed SATA II (3.0 Gb/s) drive.
OWC did a great write up on the issue in their OWC Data Doubler doc. Locate the MacBookPro8,1 listing in the compatibility listing note the Red note.
To be clear: You need a fixed SATA II (3.0 Gb/s) SSD not one that auto senses the I/O speed like a Samsung drive as it won’t correctly sense the needed I/O.
The other option is getting a larger SSD so you can run both OS’s in independent partitions within the HD bays drive.
Alright! I've been looking for a SATA II SSD, but I can't seem to find any, would you mind sending me a link to a SATA II SSD?
That seems to be the problem though, I tried to install Windows on the original HDD and it worked perfectly, it was slow indeed due to the HDD being too old, it was usable, however.
So it seems that's my issue, I'm so relieved now, I'm going to try with a SATA II SSD.
That OWC doc was of great use, thanks!
@roytrigueros98 - There are still some SATA II drives floating around from the major players like SanDisk & Samsung but they are hard to find. OWC is still offering theirs! OWC Mercury Electra 3G SSD
Roy Trigueros crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 48
