PS4 Controller model CUH-ZCT1. Released in November 2013 by Sony Computer Entertainment, this six-axis, 3.7 V lithium ion battery controller is uncomplicated to repair. (NOTE: Teardown guide is NOT for this model)
Left thumbstick dead and somehow binds to L2
As the title reads, But to be more precise the thumbstick wasn't drifting but got like deadzones, picked it apart and cleaned the rokker, worked like a charm for a while (month maybe) then started doing it again slightly more.
So I figured I left some debris or gunk in it, picked it apart etc. This time tho when I tried it the stick was completley dead.
I was playing styx:master of shadows before I cleaned it and so I started it up immediately after I was done cleaning to test (I tend to use d-pad in menu, so i didn't notice the stick until in the game), nothing happened on the left stick but all the the others buttons seemed to work (don't think I tried touchpad tho), and I noticed that the L2 button both does it's intended action and moving character forward and slightly to the left also noticed graphic glitch on the character, thought it might be the game glitching, so rebooted but problems still stands even the graphic glitch!
Tried my other controller which I've had for longer, used more and never had any problem with. And none of the problems occurred.
So my conclusion is, since the board and all of the pieces in the controller looks fine that I probably damaged one of the cords, and that's what's bridging stick/L2 button
But I don't know? Any ideas or experiences?
All analog functions (triggers and sticks) are linked toghether in the dualshock 4 and can interfer between each other when one of them is not behaving as it should.
A good exemple of that is if you only plug in the motherboard (without the conductive film for L2, R2 and all the others buttons), you can actually activate L2 and R2 with the respective joystick.
An other thing that could have cause the fault on your controller is if you break a solder joint while cleaning the potentiometer or if the conductive film was faulty.
I hope that this can help you or someone else ;)
Solved it. Unsure how since the cord wasn't necessary to use the controller( found out through testing it without, changed it ). Cleaned it out again (accidently put 2 of the pieces of the thumbstick together upside-down, which inverted the stick) and it suddenly started working but really bad drifting/deadzones. Picked it apart cleaned it out again and turned stick pieces right-side up and now it works normal again.
So not a clue what binded the L2/thumbstick
i got the same problem, was playing fifa and threw my controller and now it’s bonded together any idea how to fix
Clumsy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,705
