Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
How to shut it down without touchscreen
I need to replace my touchscreen but I can’t figure out how to turn it off so I can safely open it. I know about the hold “power button + vol down” to hard reset it but I need it to stay off. Thanks for any help.
Hi @yelpats ,
Have you tried just holding the power button operated to see if it force shuts down the tablet?
Just a thought.
Thanks for your response. Yes, I have tried that but it just pops up an option to shutdown via touchscreen and if I continue to hold it, the screen goes to sleep. I held it for about a minute.
Hi @yelpats
You may just have to carefully open it and disconnect the battery as soon as it is accessible.
As long as you can avoid operating the buttons and touching the systemboard with metal tools etc (or fingers), i.e. shorting out components, until the battery is disconnected then it should be OK since the touch is not working anyway.
With most devices these days the power button is not a power isolating button anyway. It merely provides an earth when pressed to signal to turn on/off the device
There is always power at various points on the systemboard even when the device is off. It is merely in an extremely low power state, just enough to maintain the settings and waiting to be started.
Here’s the ifixit Samsung Galaxy Tab A 8.0 guides, that may help
Try connecting a USB mouse via a OTG cable -example only and use it to navigate through the tablet. Not sure if it will work to shut down but should be good enough to allow a backup just in case
Just a thought.
I’m new to this site so I hope I’m replying correctly but I was able to disconnect the battery after point it @jayeff. I knew that was an option but I’ve always been able to turn off anything i worked on and I guess my grandfather trained me “too well”. I gained confidence by your response and was able to disconnect the battery after slightly opening it. Thanks a ton and I sincerely appreciate your time!
@yelpats
Glad to help.
The old maxim of "power off first, on last" when repairing electronics is harder to do these days simply because manufacturers don't make it easy to remove the power without some dis-assembly first and also to reconnect it last thing when re-assembling it back again. All you can do now is to disconnect it as soon as possible and reconnect it as late as possible and be extra careful, so as to limit the number of potential electrical problems from happening.
Cheers.
Josh Stapley crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 2,722
