What’s wrong with my iMac and it’s LCD?
I recently got given this iMac by my father with the following problems :
I have replaced the LCD only and am now thinking maybe its a LCD connector issue with relation to the pixel scattering on the screen.
Then there’s the issue of it not actually booting up and staying on this console screen. I have a bluetooth mouse and keyboard for it but they seem to be useless until I connect them using the GUI.
Any help would be greatly appreciated!
ps i also think the disc reader has a disc stuck in it, how would i go about extracting it without buying an new one or breaking this one.
crwdns2944067:013crwdne2944067:0
This series needs a USB keyboard to control its book options.
I have one but it a regular keyboard used on my windows PC will that suffice?
Yes, that will work! See if you can get diagnostics to come up press the D key.
Mac startup key combinations
After running the hardware test, its says in the test results no trouble found, pass number 1 with total time tested being 7 mins exactly
Running an extended test as we speak
crwdns2934275:08crwdne2934275:0
To eject a DVD, hold down your mouse button on startup.
Thanks dude this got it dislodged
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
I’m not sure why you thought the issue was the LCD.
You are facing a kernel error within your OS files or it could be hardware. You clearly have a logic board issue as the graphics is messed up on the display, so I would have replaced is the logic board first:
20” iMac Core 2 Duo 2.66 GHz logic board Apple P/N: Rev-1 661-4984 or Rev-2 661-5136
You likely will need to reformat and install a fresh copy of the OS this system requires if you are still getting the memory errors.
Roguen Walker crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 141
