A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Keyboard replacement guide - where to find?
Could someone point me in the right direction of where to find the guide to replace a1708 mbp keyboard? just cant seem to find it. thanks
unfortunately I have the same problem and Authorized Apple Service Provider wont help
@yuwonowibowo - Fire off an email to big Tim tcook@apple.com. Tell them the service providers name and the reason they refused to fix your system under the extended warranty program. As long and you didn't damage the physically keyboard they should fix it! Don't let this slide!
Otherwise you'll need to replace the full uppercase as I laid out below.
thanks for the reply Dan
The reason you can’t find one is Apple is servicing the Butterfly keyboard issues for free! They are replacing the full uppercase assembly transferring your display, logic board and bottom cover over.
Keyboard Service Program for MacBook, MacBook Air, and MacBook Pro
You can do the same using one of these:
Even if you wanted to replace the keyboard alone is not an easy job as there are riveted in! So far I have not found a source for them either.
@danj I definitely won't be eligible for the service, as I’ve poured some sort of glue onto mine smh lol.
@mxc_95 - How & why did you do that?
@danj just being stupid really. NO other explanation haha
An expensive mistake ;-{
Micko crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,045
