The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
What means Greasy yellow fluid in the valve cover air vacuum hose?
i have a 2006 nissan altima 2.5l SE. I was changing the starter motor. When a removed the vacuum hose between the valve cover and the intake was some greasy yellow fluid in the hose. I thinh oil mixed whit antifreeze? What that means? And how could i fixed?
crwdns2944067:04crwdne2944067:0
We need to see what it looks like, and where it is. Sounds like a head gasket issue since yellow usually points to that.
I took a shot in the dark to put an answer out, but I aimed in the direction with the best chances.
You can get a head gasket tester that can check if it has carbon monoxide in the cooling system to verify. You can also see if you have a cylinder missing which can tell you which cylinder has the leak.
@barriphone It's almost certainly the head gaskets and other seals. Classic Nissan defect post Renault. Individual testing is redundant - even one leaking is still a leak.
The only individual test worth *doing* is a cylinder pressure test.
It will probably have a cylinder misfire code in it and what cylinder it is.
Check for a head gasket leak - these 2000-present Renault Nissans regularly blow out hed gaskets once they start to run up mileage that is just broken in on a Toyota or Honda. You can get a kit on Amazon to confirm, but I wouldn't be surprised with a Renault Nissan.
We don’t know which engine you have, but the risk goes up at the 90k+ mile range and gets worse as you near 100k. You can find a head gasket kit here (all seals and bolts). To do every seal requires the engine to come out, so you may need to defer this to a mechanic due to bad Nissan design. Valve body shouldn't be TOO hard. Be warned for a lot of Nissan/Renault engined the head gasket is a known PITA job.
It water or antifreeze is the oil. It sounds like a blown head gasket or a cracked head.
lorospeleo crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 365
