Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
crwdns2934591:0405crwdne2934591:0 crwdns2934593:0crwdne2934593:0
New Battery is a dead battery after a month
I purchased a battery from Ifixit for my MacBook. IF161-107-3 MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Fix Kit. A couple weeks into using it the battery would drain within 30 minutes. Now even though it says the battery is 100% it dies as soon as you unplug it. The MacBook only starts up if I have it plugged in. Also I did the coconut battery test and it says the battery is running at 67%. Original battery is 6900 mah but current full capacity is 4591 mah. It been cycled 22 times for a full battery and has a cycle rating of 1000. I have no problem buying a another battery but someone said to me that because the unit is older the motherboard is draining the battery and it’s pointless buying a new one. Also, I have undated the memory to 16GB and hard drive on this computer. I’m open to any suggestions. Thank you.
update: here are the requested photos. Plugged in, not plugged in, about 2 hours later on standby mode and then died quickly. This time I was shocked. It took a while for the battery to charge but once it hit 100% the computer worked for a few hours. First time in a long time. Though I know it should be longer.
crwdns2944067:05crwdne2944067:0
install this app CoconutBattery take a snapshot of the apps main window and post it here for us to see with the MagSafe charger plugged in and a second while on battery alone Adding images to an existing question
The iFixit battery has a year warranty so find your paperwork so you can get a replacement if thats what's needed here. But lets make sure thats the problem first.
I added the first picture, I will try to add
one when I unplug it. It only last a second so I hope I’m lucky. Thank you for responding so far@danj
@kavleasgr - John this is not CoconutBattery but a cheap knockoff!
Trust me get the real one from the link I gave you. It's FREE to tryout and offers much more useful info!
@danj ohh wow, okay I will. And I will follow up. Thanks
Hi Dan, I uploaded the new photos with a update what happened! Thanks@danj
Time to contact iFixit store to get a battery exchange iFixit Customer Support
I can only use my computer while it is plugged up. When it is unplugged it is dead.
I need a new battery for my MacBook Pro please
crwdns2942205:01crwdne2942205:0:
John Gliatis crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 497
