Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
Slim and Pro disk drives - interchangeable?
Basically, I have a PS4 Pro with a defective drive and tried to test the console with a working drive from my ps4 slim.
When I swapped the drives, it would spin and the laser would shine, however I did not get the disc icon on the top right on my screen.
Thus the question: Are the disk drives between PS4 Slim and Pro interchangeable?
Follow up question: If they are, what component could have failed so that the drive spins and reads, but I do not get the cd icon on the screen? (F6202 was blown and replaced on the pro, and still getting su 42118-6 when updating)
Thanks!
Did you check all the other fuses? I believe Andrew Paul on YouTube has a video about checking the fuses on this.
The PS4 Slim and PS4 Pro Blu-ray drive assemblies are interchangeable.
The difference between if I remember correctly is the length of the ribbon cables which would require swapping them over.
The other component that may be faulty is the BD-Drive Controller Chip, there’s two of these kinds of chips one is replaceable and the other is not due to it being paired with the console.
The original Blu-ray drive should be still good to re-use but you probably need to swap out the disc feed motor as that sometimes is blown at the same time the fuse blows.
So yes, I did check the other fuses, but could not find a dead one. Do you maybe have a list of fuses that are relevant? What I tried to do is check the 4 ones that are mentioned in a few videos, and test all the other fuses that I found.
The drives being compatible, I would isolate that case for now and look for problem on the mobo.
I have a donor Slim board that I would be able to take out chips from. I believe the Renesans chip is married, right?
Stefan crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 131
crwdns2942667:0crwdne2942667:0 5,374
