The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
Samsung Galaxy Tab 10.1 cannot get home screen to appear
My tablet Samsung Galaxy Tab 10.1 when I power on Samsung Galaxy Tab 10.1 will appear for a few seconds you can hear the sound powering on but still no stream I have tried pressing power on and volume down for 10 seconds and the same thing happens I've also tried holding down power and pressing volume down holding down until I get a Android image telling me downloading it will not go off until I power down
Hi @azronnie,
Try the following:
a). Wipe the cache partition of the tablet and check if it then starts OK.
b). If still no good try starting the tablet in safe mode and see if it boots OK.
If it does then a downloaded app is the cause of the problem.
You will need to uninstall each downloaded app, one by one and test the tablet in normal mode between each uninstall. When the tablet works OK then the last downloaded app that was uninstalled was the cause of the problem. Try starting with recently installed apps or updated apps.
Thank you Jayeff I've got this to appear: warning a custom OS can cause critical problems in tablet and install application volume up to continue volume down to cancel what would you recommend
Thank you so much you've been a great help
Ronnie Green crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 440
