The OnePlus 6T is an Android smartphone made by OnePlus. It was announced on October 29, 2018 and released on November 6, 2018.
I Accidentally scraped my battery
I accidentally scraped my phone battery a couple of times while removing the back panel of my OnePlus 6T. Should I replace the battery or will this battery still work like this? It is not punctured at all, just has some grooves on top
You should never use damaged batteries but you can add a picture of it so we can see how damaged it is.
Adding images to an existing question
Picture added to the question. If I may add, I have already charged and gone through 3 cycle charges and the battery does not overheat or anything. Would this still be considered heavily/dangerously damaged?
Even if it works fine, replace it. Normally I wouldn’t be concerned about a very, very light surface scratch but these are deep enough to warrant replacing it. Softcells have zero protection like old modular ones in a metal case.
It may be fine, but it’s not worth the risk since softcells are so easy to damage. The battery can be found here.
crwdns2886500:0Replace a BLP685 model battery compatible with OnePlus 6T and 7 model smartphones. 3610 mAh. 3.85 Volts (V). 13.89 Watt Hours (Wh).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
OnePlus 6T and 7 Battery
$14.99
Never used damaged batteries in devices, especially if you get the smell of rubbing alcohol or burnt skittles as other people have described it.
I just added a picture To my question. No smell is coming out of it. I'm just worried if those grooves may be considered dangerously damaged or not. Can I please get your feedback on it?
Yeah I'm concerned about those grooves. I would get a replacement, it's not worth the potential third degree burns.
Alberto crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 411
