White screen but still works on an external monitor
So I’ve got an A1534 Macbook which boots to a white screen, it’s still working and on an external monitor you can still use it. I’ve already replaced the ribbon cable but to no avail.
I was just wondering if anyone had any known fixes outside of replacing the entire display assembly?
edit: the MacBook is broken in the first place as a result of it being closed when an earring was inside it (just at the back near the hinge) and apparently since then it hasn’t worked. There is some damage on the front of the device but not the screen itself https://imgur.com/i98A6W6
Sounds like the displays T-CON has failed. Thats the small circuit board the display cable connects too on the display it’s self. Did you have a liquid spill or spray a cleaner onto the screen directly?
Here’s the needed part MacBook 12" Retina (Early 2015-2017) Display Assembly and here’s the guide Retina MacBook 2015 Display Assembly Replacement
crwdns2886500:0Replace a display compatible with the early 2015 to 2017 model A1534 12" Retina MacBook laptop. Includes the 2304 x 1440 pixel 12" LCD screen, aluminum case, 480p Facetime webcam camera.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$584.99
Oh yes apologies, I forgot to mention the most important detail. The macbook is broken because it was closed on an earring, there is some damage https://imgur.com/i98A6W6 on the small MacBook strip at the bottom
Still the same answer, the display got damaged, time for a new one. Sorry ;-{
Adam Chapman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 190
