Here’s a breakdown on the codes:
- PFM001 - There may be an issue with the System Management Controller (SMC)
- PPT001 - The battery was not detected.
- NDC001 - There may be an issue with the camera.
Your logic board needs some serious TLC! It depends on what happened to it. Did you have a liquid spill into the keyboard or trackpad at some point?
You’ll need to decide if you have the needed skills to diagnose and repair the logic board your self or does it make sense to bring your system to someone that has the skills, tools and access to the needed parts. To give you an idea on whats needed Battery not showing up on A1278 Unibody Macbook Pro: how to troubleshoot & repair Louis also goes over one simple fix at the beginning.
If you just don’t have anyone local you can bring your system to or it looks like there is too much damage to the logic board then the other direction is to just replace the logic board MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement. There is also a bit of a bright side here as if you have the low end model its a chance to get a better CPU!
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
crwdns2942205:01crwdne2942205:0
Have you fixed it OP?
crwdns2934271:0crwdnd2934271:0 Aksel Jeffersen crwdne2934271:0
