The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
Using a US Game Gear model in the UK?
Hi,
I have a US GG model (2110G) which states to use the 2103 AC adaptor only which has;
INPUT: 120V AC 60Hz 14W, OUTPUT: 10V DC 0.85A.
My UK charger has the following details;
INPUT: 100-240V AC 50/60Hz, OUTPUT: 9V 1A.
Is it safe to use this Game Gear by using the UK plug?
Thanks
Hi @beenz,
Assuming that your UK adapter has a DC output (you didn’t specify) it won’t harm the device.
It can operate on 6 x 1.5V AA batteries (9V) so it should work
Also verify that the plug of the replacement adapter is centre pin +ve as shown on the adapter case, (see image below of your USA adapter which shows the +ve goes to the centre spot of the circle - the circle represents the plug - inner and outer connectors).
If the UK adapter has a reversing plug attached at the end of the cable i.e. it can be flipped over to supply either +ve voltage or -ve voltage from the adapter, depending on which way it is attached to the cable, ensure that it is supplying +ve to the centre pin of the plug.
(click on magnifying glass symbol in image to enlarge for better viewing)
Hi thanks for your advice, have just came back onto this site and seen your answer
Graeme Bentley crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 339
