2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
(MacBook Pro 15" Retina Screen, Mid 2015) Display Issues
Screen flickers and has vertical lines on right side of display. Problem started out small and intermittent for two days and suddenly got worse today. Display issue does not show up on external monitor. I have already tried software fixes like resetting PRAM so problem is most likely hardware. Out of warranty and don’t want to get overcharged at local apple certified repair shop, hoping to get a clue to what the problem is before taking it in. Any help appreciated!
Sadly your internal display is bad. You’ll need to replace it to fix this. Here’s the gunned you’ll need to follow: MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement
Now the shoe drops! These displays go for big bucks! This is because many had bad anti-defective coatings. A new one goes for over $600 !! A used one can be half of that if you can find one 15” Retina MacBook Pro Display Assembly, Apple P/N: 661-02532
Jessica Herndon crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,356
