Bented phone Huawei p9 lite
Hello. Just want to post some picures of the bented p9 lite and like to ask what do you think, if this can be safely unbented without damage the lcd. I try a little bit and i'm sure that i will brake the lcd. What are the best ways to unbent the phone. Thank you.
Thank you, i will also remove an lcd, i think that it isn't glued in the middle on the frame. Hope not. Beacuse i dont think i'll be able to unbent the frame, with the lcd on. I will try, hope i make it. Will get back to you.
Gorazd Preloznik  remove as many parts from the phone as you can. You should not try to bend it back into place while leaving the motherboard, battery inside etc. Once you have removed those parts place a relatively thick round metal dowel right under the case where you see the bend crease, then try to push it back into proper position. It might take a few attempts. Of course you can also use a tool like this which should work for your phone as well. Remember that any good metal working as well as auto body shop can help you with that as well.
Huawei P9 Lite
Gorazd Preloznik crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 181
