bootable usb of mac osx
every time i make a bootable usb of mac osx it won’t boot and gives me a kernel panic so i am unable to install it on a new hard drive. i use my windows 10 laptop to make the usb and i use transmac and etcher as the programs to write the image to the usb. both programs succeed in doing so and my mac recognizes it as a boot device but when i click on it i get the apple logo and then a kernel panic. could it be a bad disc image or an incompatible usb thumb drive
I had wished you had stuck with your original question here: Why am I getting a kernel panic at boot than opening up a new one.
If you could not see a log file that tells us you are not installing a valid OS version for your system.
I figured out that one, the hard drive is bad and has bad sectors on it so it causes the kernel panic when I try to boot from it. The usb throws up a kernel panic only when I try to boot a mac osx install from it. The hard drive had no recent log on it for the times I tried to boot it up
Depending on which MacBook you have, you maybe be trying to setup to new an OS for it!
Review this listing to locate your system and then roll now to the ‘Pre-Installed MacOS:’ section to locate what is the highest you can go to MacBook A1181 models listing
As an example, the Late 2006 MacBook the highest it can handle is OS-X Lion (10.7.5) and the Mid 2009 MacBook can only go to OS-X El Capitan (10.11.6)
Make sure you are using the correct OS for your system! Even still you can encounter an issue! As Apple uses a certificate system to expire out older OS’s So installing a fresh copy of OS that has an expired certificate (which is based on a year and month) can drive you nuts!
As an example Apple messed up the certificates in the last three macOS’s (Sierra, High Sierra & Mojave) Here’s a bit more on what happened If you've got an old macOS install image, it will probably stop working today
While this is all well and good it won’t help you here! As Apple has not redone the OS Installer images for the older OS-X releases you would need.
So if the boy can’t get to the mountain, then the mountain needs to go to the boy!
So if we can’t install the OS as the certificate check will fail we need to figure out how to fake out the check so it doesn’t fail! And we can do that by programing the systems clock to year the certificate the installer has passes the check! So as an example altering the systems clock via the current OS following this approach:
You can also do this from within a terminal session as well. The important part is making sure your system doesn’t reset its year setting on its own before you’ve finished the OS install so make sure it can’t connect to the internet as it all automatically connect to the time server and correct its self.
How can I change the time and date settings if I can't boot into anything
Yes, this does get into the chicken and egg problem ;-{
At this point you need to have someone with a working Mac create the needed disk with the required OS installed.
Depending on which model you have you may need a CD vs USB drive as the older models won't even boot up via USB. They will boot up via a FireWire drive though!
Update, I burned the os on a DVD using my windows laptop and the Mac recognizes it but gives a kernel panic when trying to boot from it so os DVDs and USBs give me a kernel panic. Even without the HDD installed
Yep, that is what I would have expected! You need to create the bootable CD via a Mac system as the installer won't work properly under Windows.
i'm using transmac to burn it and it worked but it get's a kernel panic when i boot the dvd. other people have used transmac and it worked and booted for them
Cheap gamer crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 2,406
