My iPod only works when its charging.
My iPod 4th generation nano only works when plugged in. I have left it plugged into ac power overnight, and in the morning it shows it's complete, but when I unplug it, the screen goes dark and the device loses power. When I try to turn it on by holding the play button nothing happens, I try to reset it by holding the menu and center button for 6-30 seconds and also nothing happens. The device was used rarely from purchase and has been sitting without a charge for at least a year. I can listen to music while it's plugged in and "charging" but when I disconnect it from the ac power cord its a dead duck. If anyone can help me I'd be greatful.
crwdns2889612:0crwdne2889612:0 21
i have same problem
my brand new shuffle charges fully when plugged in but won't turn on when detached from charger...
@paschal smith i... dont think you can get a brand new shuffel. you probably got scammed and the battery is cooked.
Reboot it while it is plugged in. That's what i did and it worked.
crwdns2889612:0crwdne2889612:0 8
crwdns2944067:012crwdne2944067:0:
How u did this bro
Hold the Menu and select buttons at the same time for 8 seconds or until it turns off. Once you see the apple logo, it's been rebooted.
thanks was about to throw it in the trash back to normal ;)
Thank you for sharing!!!
thanks dude I was 2 seconds from letting it meet it's maker!!!!!!!!!!!!!!!!
crwdns2934275:07crwdne2934275:0
Hey Ryan, sorry to hear about your Nano. Sounds like a dead battery to me. Your best bet would probably be to replace the battery with one of our battery replacement kits. Unfortunately, replacing the battery requires some soldering, but if you're game, give it a shot! What better way to learn, right?
Hope this helps! Good luck, and let us know how it goes.
crwdns2886500:0Replace a battery compatible with a fourth generation iPod nano model A1285. 230 mAh.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPod nano (4th Gen) Battery
$13.99
and this is a hard fix..i gave up and sent mine to oldturkey!well done nick
I had the exact same issue - probably used the thing less than 10 times since I bought it, and when I pulled it back out to take a trip last week, it wouldn't charge. It really chaps me as it's still in like-new condition and was certainly not worn out! And Apple wants something like $60 to replace the battery, what a scam...
crwdns2934073:0crwdne2934073:0
I just took my iPod 4th gen apart and there was corrosion on the board so I figured I may as well clean it. Will update when I see what happens!
Ryan crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 55
crwdns2936753:030crwdne2936753:0 228
crwdns2942667:0crwdne2942667:0 83,737
