Display screen with "Red static colored"
I started to see “red static” on the borders and anywhere there's black on the screen. Doesn't show up on the Mac OS X boot screen. Pretty sure it's a hardware issue and not software since it goes away when I close the lid about 3/4 of the way down, but the problem is getting worse every day. I suspect that is the ribbon cable that connects my display to the logic board , any suggestion about how to replace it are welcome!
Try starting up in Safe Mode by holding down the Shift key on start up. This will confirm if you have a hardware or software issue if the symptom disappears.
If it’s gone, install a good “Paid For” antivirus like Symantec and run it.
Hello,
Thanks for your reply. I test it on Safe Mode and the problem continue. So is Hardware :(
Regards!
Ok, now lets see if we can narrow it down. Hook up an external display and see it it appears on the external. If so, you have a GPU issue, if not then we go to the display.
A red screen is apple’s version of the blue screen of death.
crwdns2889612:0crwdne2889612:0 -1
crwdns2942205:01crwdne2942205:0:
So, Purple is Goggles screen of death ?
Red is just a color it's not a sign of a OS failure its a sign of a video signal getting messed up.
Frankhil Contreras crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,554
