Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
Driver side Turn signal doesn’t work.
Looking for some help it’s a 95 accord lx 2.2 automatic and I could really use some help not very car savvy but I’m willing to learn so please be detailed and thank you in advance but yeah I replaced the bulb on the signal next to the headlight and the one on the bumper “looks” fine what next?
Hi @notreally ,
Does the instrument panel left turn indicator light work?
Can you hear the turn signal relay operating in the cabin when you operate the combination light/turn signal operating lever to turn left?
If you can’t when you operate it to turn left but you can when you operate it to turn right then you have a faulty turn signal lever switch or a wiring problem between the switch and the lamps.
Do the driver’s side turn signals work when you operate the hazards light switch?
If they do then you have a faulty turn signal lever switch.
If they don’t then you have a faulty wiring between the lamps and the signal turn switch or the hazard switch. I don’t know where the wiring runs to first from the lamps.
Here are two images that may help.
The first is the circuit diagram for the lights and the second is how to test the combination light /turn signal switch to check if it is OK.
(click on images to enlarge for better viewing)
Check your fuse box for a blown fuse. Your owners manual should tell you which one to look at.
double check the bulb, the harness that plugs into the bulb for any dirt or damage, fuse box for blown fuse and failing that the wire itself for any breaks.
Luis M crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,073
