The Huawei MediaPad M3 is an Android tablet launched in October 2016. Model numbers: BTV-DL09, BTV-W09.
Can the battery be changed?
The guide so far deals with opening the device by heat gun and changing cameras. But what about the battery? Is it glued in? Does it come in greater capacity? And what temperature for the gun?
Thank you!
@impro use something like this guide to at least get to it Huawei MediaPad M3 Motherboard Replacement . Yes the battery is adhered to it but can be replaced by gently using a non-metallic spatula etc. to jimmy it loose. Stick with a battery to is made for your device and there are no large capacity batteries for it. As for the heat gun, it is only to be used to heat and soften the glue. Do not blast the heat straight onto your LCD and keep the heat gun moving along the edge. To much heat will burn your LCD screen. There is no exact science for that heat gun but usual temperatures for this type of job is between 80 and 100 degrees Celsius with 80 degree Celsius being standard. To hot and your LCD will get damaged.
kenneth krabat crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 610
