The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Phone charging but not charging
My daughter got slobber in charging port. I was able to dry it but unfortunately my phone doesn't charge it stays at 1% when it's off and when I turn it on it goes down to 0%. Any suggestions on how to fix it?
Hi!
Check if there is corrosion on the pins. If yes, try to clean it with isopropyl and then dry it again.
If it’s still not working, replace the charger port (it’s not soldered on the motherboard, and it’s the best thing to do anyway). Before you order a new one, open it up and check if there is corrosion anywhere else, if yes, clean it and check if everything else is working. Order the part, build it in and enjoy!
jackiejacklin63 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 161
