no sound after speakers replacement, but laptop makes popping sound
hello everyone, my laptop randomly started making this horrible sound whenever i would try to play a video or listen to anything with the internal speakers. it would also make a popping sound before a video would start or when i would turn on or off the laptop.
so i bought replacement speakers and followed the instructions very well, im certain i did not mess anything up and put everything back to where it belonged, it was fairly easy. but when i turned on the laptop it still makes those popping noises on boot up and shutting down, also when im about to play a video. the good thing is that no horrible noise comes out when trying to listen to something, the bad; there is no sound in general. nothing at all.
so my question is.. what should i do?
I wish you had asked us first how to diagnose your sound issue.
What does a bluetooth speaker or headphones sound like? Lets see if the the issue is limited to the analog side.
If that bluetooth connection sounds OK unlike your internal speakers lets try a wired speaker or headphones does that also sound good?
Darn I will remember that in the future. The MacBook doesn’t have Bluetooth , but if I connect headphones in it sounds perfectly fine
Are you sure your bluetooth is not working? This system does have it. That maybe a clue here!
2015 Retina MacBook models
In any case the fact the headphone jack is offering a clean signal it telling me the amp logic is not working in the audio circuit MacBook 12" Retina (Early 2015-2017) Audio Board
crwdns2886500:0Replace the circuit assembly that supports the audio in/out port.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$39.99
Thanks dude I’ll replace the audio board and I’ll come back and let you know if it worked. I’m almost positive there was no Bluetooth option, but I’m not home right now to check. Thank you again ! & happy holidays.
@docbrown77 - No, your system does have Bluetooth! I added your systems specs above.
quick update; im dumb lol there is bluetooth on this thing and it works perfectly. i just purchased the audio board so i will update again after i replaced it to see if that fixed the problem.. do you think i should also purchase a new audio board flex cable
yuderka aybar crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 91
