The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
Areas of screen unresponsive to touch after screen replacement
I am just about done with the iPad 6 Wi-Fi Front Panel Assembly Replacement procedure. The LCD is screwed back in with the new touchscreen connected. I turned on the iPad to test the touchscreen (before final step of removing adhesive strips and securing touchscreen down).
Home button works fine - iPad lights up and when I go to enter my code, the 4, 5, 6, 7, 8, 9, and 0 all seem to work but the 1, 2, and 3 buttons do not respond to touch. “Delete” and “Cancel” text buttons both work.
I am able to power down (by sliding across the top of the screen) fine. Tried a hard reboot but same issue persists.
Is this a problem with the iFixit replacement screen or could there be another issue?
Thanks.
Oh yeah I get this a lot with my iPad 6 screens just disconnect the screen cables and reseat them. For every one I do I plug them in two times to make sure.
I'm not sure why but with first click in it sometimes has dead spots on touch but when I reseat it is all working fine. Make sure to push down a bit harder than usual on each ends to make sure they are fully clicked into connector.
Thanks! I will try this and report back!
Belated update: this fixed it - thanks!
I'm replacing a new screen. 4 5 6 and above doesn't work, below that works. What itmeans "in two times"? Pluging the connectors restart and then unpluging and puld the connectors again? Thx in advance.
Matthew Wilson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,400
