The Samsung L100 is a digital camera that was released in February 2008.
My camera wont stay on.
The camera comes on, the green light on the back flashes once. The lense starts to come out, then immediately retracts followed by 3 beeps.
crwdns2944067:06crwdne2944067:0
I go with a stuck lens. It can cause errors the way you described yours. Check on here for more info
I'd agree with oldturkey, it's a good link too
Hi there
I'm sure you have problem with lens of camera . is not that eays to be fix by ur self if you don't have exprince on repair camera but you can try .
you have to know some time after fix it stil you have problem that is u can see line on you lcd screen . is mean you have change your lens .
I do repair cameras .
Hi there
I think you had problem with lens Of your camera ./ maybe you dropprd your camera.
cyrus_7029@yahoo.com
I seem to be having the same fault with my Samsung L100 camera. I fitted a replacement battery and still the same fault is present
First, a easy fix, charge the battery overnight, put it in, power it up, if you yield the same result, replace the battery and see what happens
I will update this after we have more details on what happens and what you did to troubleshoot
I think the answer is in the question Read the second sentence carefully....
matt crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,854
