Can I run this under 19v
so I have this and I don’t have a charger for it can I run it off like 15v or 12v if possible if I can what hardware do I have to take off to make it run?
no lest then 18 volt
so I cant do it under period? but I can do 18? in order to make it run on 18v do i have to remove anything?
nothing to remove u only need a 18 volt adapter or 19
The voltage regulator inside should handle an undervoltage but I would not go too low as this will cause excess heat.
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 106
