Hyundai launched a redesign of the Santa Fe on February 14, 2012, and went on sale in June 2012 as a 2013 model.
Car vibrate at 70-90 km
My car vibrates at 70-90 km and once I cross 100 it become completely normal, I thought it might because if tires balancing but I got the balancing done and it still continues, does anyone know what’s the problem thanks
Does the steering wheel also vibrate?
Yes I can feel it, the whole car vibrates
Jignesh Patel yours the All Wheel drive model?
No fwd 2.4 litre engine
You likely have out of balance CV assembly
These are the symptoms of a bad or failing CV axle shaft assembly
I will have to check with my mechanic.
Jignesh Patel  rotate your tires or change your tires. Have a good mechanic check your front end including the ball joints and tie rod ends.
I rotated the tires but still the same problem, in fact, I changed my all-season tires with Winter tires and still have the same problem.
Jignesh Patel crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 290
