This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
crwdns2934591:078crwdne2934591:0 crwdns2934593:0crwdne2934593:0
hello can I fix vertical line 4 inch going from top to bottom?
I replaced logic board because I thought it caused problem but please look at the pictures
there is 4 inch line going from top to bottom is it LCD or connector cables inside?
just replaced T-CONE did not work, still same strap 4 inch going from top to bottom
need help
I am thinking may it be video cable connector?
need help, T-Con board was replaced and same nothing changed
This looks like a messed up T-CON board issue which is on the backside of the LDC panel. Here’s the P/N for the full display Apple P/N 661-5542. Here’s one source 661-5542 Apple LCD Display for 27" LED Cinema Display. I haven’t used them let so let us know if you have any issues.
crwdns2942205:01crwdne2942205:0:
thank you ! I will buy it and replace
Michael Niedzwiadek crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 86
