Bose SoundSport Free are wireless earbuds from Bose. Released in 2017. Model number: 774373-0010.
Can the batteries be replaced?
Is there a trick to replace the batteries? I found we can find some on ebay…
Hej iFixit! thinkg you should include Bose products aswell!!
It seems you can get parts here and a teardown and battery replacement video is here
Thank you for your reply @uchetil. I’m sorry I haven’t replied sooner.
Replacing the battery requires heat, and soldering/desoldering. I plan on fixing mine either today or tomorrow. There is a good tutorial on YouTube. You have to make sure you get the battery for the Soundsport Free Wireless, not the Soundsport Free. They aren’t interchangeable as far as I’ve found.
crwdns2944067:07crwdne2944067:0:
Did you succeed? I got replacement batteries (Varta CP 1454 A3) via ebay. Now very anxious about doing the repair because I am still a repair rookie. Especially the re-soldering of the battery looks hairy to me.
But I just don't want to throw away earbuds which I just bought 2,5 years ago.
@codamo Sorry for the late reply Martin. I ruined my earbuds. I pried on the wrong place and destroyed my volume controls. Be very careful where you pry and how much pressure you use. Without that setback, I would have been successful.
Hi, how long did you applayed heat and at which temperature? Thank you very much in advance
I used the iOpener on the earbuds. I left it on for about a minute, but it was still tough to remove.
Hi, does anybody know alternative point to solder battery to board? I managed to break terminal from board.
crwdns2934275:02crwdne2934275:0
The Bose SoundSport Free headphones are not designed to have their batteries replaced easily, as they are soldered in place. However, if you want to replace the battery yourself, you will need to have some electronics repair skills, as you will need to disassemble the headphones. If you are not confident in your repair skills, take your headphones to an electronics repair shop or Bose service center to have the battery replaced safely.
shimmeul crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 111
crwdns2942667:0crwdne2942667:0 7,748
