The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
MacBook Pro fan not working properly
Guys I have an issue with the fan on my MacBook Pro 13 inch 2015. I already changed the fan . Already Reset SMC and NVRM Few
times
issue : It never start after you press the power button . Even after 5 minutes it doesn’t start . I downloaded istat and it showed RPM 0 even when It’s 50C or 122F .. it does rotate when temperature goes higher like 70C or 158F but 1260-1300 rpm only
so something is not right . Can you tell me what should I look at . Why it is only spinning at high temperature and why it never spin after you press power button
SMC which controls the fan gets thermal data from the sensors within your system. Depending on what they are reporting to SMC the fan will engage and as it’s a variable speed fan it will run at different RPM so the air flow across the cooling fins will be at the needed intensity to shed the buildup of heat. Apples thermal template algorithm is designed to be less aggressive at the lower thermal load so it does take a bit of load for the fan to start up.
From what you are stating it sounds like your system is running as designed.
The ability of your monitoring app may bias your view point. As you can’t see your fan physically and a single snapshot may not offer enough granularity on what’s happening, You should try an app which records over a period of time. I personally prefer this app TG Pro as the full version will get you that.
You do appear to have dirt on your screen or is that damage?
Kamran Chowdhury crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 313
