MBA 2012 Logic board in MBA 2011 case
Hi,
I want to upgrade my MacBook Air 11’ 2011 with the new MacBook Air 11’ 2012 logic board because I found a friend who want to sell me this very very cheap.
Is it possible to buy logic board + io board + wifi card + SSD from MBA 11’ 2012 and put it into MacBook Air 11’ 2011?
Looks like it will be an easy switch because display battery and keyboard are fully compatible. For SSD I will just change the cheap adapter from my old MBA 2011 M.2 SSD.
Often times Apple alters things enough between the series runs Mid 2011 - MacBookAir4,1 Vs Mid 2012 - MacBookAir5,1 so the parts are not compatible.
This is one of the rare times they didn’t. The logic board is functionally a direct drop in, But you will have an issue with the display not working properly, but it will work! The displays ID is the issue.
I would stick with your current SSD unless its running out of space. If that’s the case I would strongly recommend sticking with the real Apple SSD’s or either OWC or Transcend SSD’s as they are designed to be compatible.
I don’t recommend using M.2 SSD’s with the cheap adapters being sold.
crwdns2944067:09crwdne2944067:0:
Please tell me more about issues with display and how to solve them. I found in the internet that some sellers offer "2010-2012 MacBook Air displays" which make me think that they are identical.
The Extended Display Identification Data as well as the FaceTime camera are different.
The LCD panel is identical its size and scan, the system EFI will list it correctly.
@danj What kind of visual issues to expect if System EFI won't list correctly my display? I will need to install additional drivers/kexts to boot macOS? Or I will just see some abnormalities on screen ?
Bootup will not show the loading thermometer. You'll get a flash of the Apple Logo then the display will go blank and then the display will show your desktop after the OS is fully loaded.
@danj is it possible to solve the issue by overriding the monitor EDID? For example, by placing overrides into /System/Library/Displays/Overrides ?
crwdns2934275:04crwdne2934275:0
One other key issue preventing easy success is that the 2011 model uses MagSafe 1 whereas the 2012 model uses MagSafe 2, and the cutout for the MagSafe 1 connector on the body does not accommodate MagSafe 2 dimensions.
Misha Krasnorutsky crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 387
