The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Can NOT turn on and charging light stays amber
Hey, I cant turn on my MacBook air after probebly running out of power.
No Sound, light or any sign of action other then the amber light on the charger.
resetting the smc turns charger light to green and back to amber.
Letting it charge over Night still amber. Disconnecting battery and pluging in charger does NOT change the amber light to green and still no action.
Hope somebody Can help me
Kind regards Michael
With the battery disconnected are you able to start the system with just plugging in the MagSafe charger? The system should spontaneously boot.
If it does you'll need a new battery MacBook Air 13" Early 2015 Battery Replacement
Update (07/09/2019)
At this point I suspect your logic board has a problem. You’ll need to find someone local to fix it or you could just replace it MacBook Air 13" Early 2015 Logic Board Replacement has the logic board info inside.
crwdns2886500:0MacBook Air 13" Early 2015 Logic Boardcrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
1 - 2 hours
crwdns2886500:0MacBook Air 13" Early 2015 Batterycrwdne2886500:0
15 minutes
Hey Dan, Thank you for your quick answer.
No, when I disconnect the battery and plug in the MacSafe charger, nothing happens and the charger light is still amber instead of green.
@danj I had the same problem and your answer allowed me to troubleshoot my problem. Luckily it's just the battery. Sorry Michael that you had a logic board problem. Thank you, Dan!
@evanga2so - Thats great!
Michael Klostergaard crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 458
