Model A1993. 2018 refresh of the Apple Mac mini. Processor options include 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5, and 3.2GHz 6-core Intel Core i7 processors.
Startup loading bar blank screen
When startup, the loading bar reach 70%. The monitor turns to save mode and blank screen. Press monitor power button. Turn off and then turn on again. The login screen is appeared. How to fix it?
更新 (2019年07月01日)
cannot fix the issue.
First try starting in Safe Mode to see if you have extension issues.
Boot up holding down the Shift key.
Next see if you can boot to the repair portion.
Hold down the Option key on boot and see if you can select the Repair Partition. If you can, then run Disk Utilities.
Given the age of the system it should still be under warranty. I would visit an Apple Store or authorized services center to get it repaired.
It sounds like your storage has a defect unlike the older mini's the storage this series uses an intergraded flash array via a T2 controller. Your logic board will need to be replaced.
Tommy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 163
