Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
MacBook Not Powering Up After Display Cable Replacement
I just followed the guide to replace the display cable. I connected everything up, left it charging overnight, but no luck when pressing the power button in the morning. I don’t think the display cable directly affects turning on the machine, so I was wondering if I possibly knocked something loose elsewhere?
Well, very likely there was/is some mistake on disassembly or reassembling..all the “it doesn’t work after replacing this or that” head that way. Unless you shorted out something along the way it should be sufficient to double check your work once more and make sure flex cables are correctly plugged in. The 2016 retina doesn’t have any other specific/typical issues with keyboard
Eric crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 69
