A 10.1" touchscreen tablet released in 2014 by RCA Corporation.
stuck on the rca screen that has the pups on it
why is there no answer for this question? I have the same problem resetting it with the pin in the back doesn't even work. can we get an answer?
I was given a RCA MODEL RCT6203W46 when I try to turn it on or I plug it in. It goes to the screen with the pups on it and then off and it will do that u til I hit the reset button on the back.. I have tried the volume up and power button and it goes to pup screen and then back off.. What can I do to get it to turn all the way on.
mine was stuck on the rca pup screen i unplugged it and when i turned it on i held the button down instead of just pressing it and that worked!!
Barry Martin sounds like you have an issue with the operating system. Try to Boot into recovery mode by pressing and holding the volume up and power buttons. Once the RCA screen (the one with the dogs :-) comes on, let go of the volume up button and you should see an android image. Press and hold the power button and tap the volume up button once more and this should bring you into the recovery mode menu
Is there another way to reboot? My screen is stuck on the pups and will not reboot using the method above.
I got same problem and the way I work around it is I unplug it then after the light goes from red to white then back to red I push the power button and hold it it turns on and keep holding and after about 3 secs it goes changes screen after first time u sometimes don't have to unplug it first but sometimes u do it doesn't work as well with remote but sometimes it does as long as it's pointed at projector whole time
My tablet wont go past the rca screen I tried the reset button just went back to the rca screen. I tried the holding the power and volume up buttons and nothing happened. What can I do to get to the reset screen and how do I get past the rca screen
Barry Martin crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 174
crwdns2942667:0crwdne2942667:0 4,643
