Possibly Fried the CPU
So today at work I approached an object with a large amount of static electricity built up on it. I approached the object from the side I keep my phone in my pants pocket, and when i got close enough, the static discharged from the object, through my phone and into my leg. I was listening to music through bluetooth headphones when this happened and as soon as I felt the shock go through my phone and into my leg, the music stopped and my phone was totally dead. It hasn't turned on since and plugging it into a charger yields no response from the device whatsoever. My guess is the zap fried the CPU and totally bricked the phone. I had over 10,000 pictures on the device, none of which were backed up at all. Is there anything at all that I can do to save my pictures or get my phone to work again? Right now it's a glass and metal brick that I paid $900 for. Might I be able to send it in to Samsung and have them run a some kind of diagnostic to determine which component(s) was affected by the static discharge and replace them? Is it even possible to replace a CPU if that's what the problem is?
Wow…what is this evil device that can zap a phone in your pocket?
There are several hundred different components on the logic board that can be zapped and cause the phone to fail entirely. This may not be a CPU issue and chances are the data is stilled saved in memory. If Samsung is anything like Apple, they will do absolutely nothing to help you recover your data. The issue with the S8 is that the data is encrypted by default (unless you deactivated that feature) which means the only way to recover it is to fix the logic board.
So start searching for reputable repair shops that do micro-soldering work and data recovery on smartphones (avoid hard disk focussed shops as they generally struggle with phones).
Joe crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 657
