Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
Screen turns on then turns off post screen replacement
I replaced the screen on my son's iPad mini 4 and I've had nothing but issues since. The screen will turn on for 5-20 seconds then go black but it's not like the screen turned off, I can still see light on the side of the LCD. To turn the screen back on I have to press the sleep wake button twice, once to turn the screen off then again to bring up the screen where you have to press the home button to enter a password. I have also replaced the sleep wake sensor as well. I was very careful when I took everything apart, I always disconnected the battery before I removed the screen and digitizer. I've forced restated it (home and sleep wake button) and factory restarted it as well in iTunes. I was very delicate with the screens as I handled them to avoid damaging the ribbon connectors. Has anyone seen this before or have any tips? I'm not trying to open a business, I was just trying to save some money and do the repair myself.
If you are confident that the battery was disconnected before removing the screen and only reconnected after the screen, then I would double check the condition of the connectors, the flexes and the small components surrounding the connectors. You may want to use magnification unless you have young eyes :>).
If you have second thoughts (about the battery), this does look like a backlight circuit issue and this would be repairable via a micro-soldering repair.
Beyond that, I would try to re-install the original screen if it is still in working condition. You may have a bad re[placement screen.
Update: it worked fine for almost 5 minutes today before it went black again, I don't think it's a back light issue because there is no image visible when the screen goes out
Ryan Smith crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 167
