2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Replaced battery now I cannot log in
SO, I replaced a bulging battery yesterday with an Ifixit replacement. It worked great after the replacement, ran the battery all the way down to help condition it and calibrate. After the macbook shut down I put it on the charger and it sat amber for about 4-5 hours. Something seemed off, so I booted it up to look at it and there is a triangle with an exclamation point in the battery. So I reset the SMC, no luck, next I reset the NVRAM, no luck. Ran a diag, says battery needs serviced, the weird thing is I cannot login at all, it gets about 20-25% of the way through the login screen then it reboots and I’m back to square one. I have tried to restart and do ye ol’ cmd+r, nothing, just boot loops. Tried safe boot, no luck. Anyone have any ideas, my guess is a $@$* battery, just weird how it worked fine on the battery after install but when it powered down it seemed to $@$* the bed.
Batteries are a painful topic, if you do a search on the forum questions you’ll see there’s someone having troubles every day, especially with aftermarket batteries. Your Mac runs off charger only too, thus you have an easy testing tool available, just unplug the battery from the board and see what happens. If it’s a battery issue the Mac will boot on its own and allow normal operations as soon as you connect the magsafe charger, in which case just ask for a battery replacement. If the issue is still there..well, let’s hope it’s not there to start with ;)
I have the same issue, unfortunately this solution didn´t help.
The loading bar after trying to login was constantly getting up to 1/20 before restarting - then I reseted NVRAM and now it goes to 1/5 and then restarts :D.. It´s the same when the battery is unplugged.
I followed this tutorial - MacBook Pro 15" Retina Display Mid 2015 Battery Replacement - do you know where the issue might lie? Is it most likely caused by permanent damage to something or do you think there is still a chance of making it work again?
Thank you very much,
Jan
@Jan Kršňák A number of issues may give the same outcome, thus it's hard to diagnose something like what you're experiencing..it may be software with a corrupted system, a faulty SSD or even a logic board problem. Try these hints to start with, so as to to try narrow down the issue: https://support.apple.com/guide/mac-help...
Since this was a battery related question that was already closed, please do create a new one in case you need further help :)
@arbaman great, thank you very much for your help, I will check it out
@Jan Kršňák - If you can get your system running install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question that way we can see what's happening with your battery and charger logic if it's not a software issue.
Nicholas Bates crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 745
