The Scotch model TL901 is a thermal laminator that laminates flat items up to nine inches wide. It includes two temperature settings and will laminate pouches up to five millimeters thick.
Scotch TL902 laminator assembly instructions
I recently got the scotch laminator tl902..the sheet was jammed so,I opened the machine and removed the jam..But, now unable to assemble it back..Any step by step instructions with pictures would be great help
How can I close the input tray on my laminator tl902 when finished and want to put it away?
How do you get the insert tray out in the position needed to insert
laminating sheets?
Hi,
Here’s a link to the ifixit Scotch TL901 Teardown guide, which may be of some help
You may be able to reverse the procedure to re-assemble the laminator.
Research online indicates that the only differences between the TL 901 and the TL 902 is that the TL 902 is newer, lighter and has a side handle for easier carrying.
how do you get the back to open to put pouch in... brand new
@ann45280
You don't need to open the back.
You place the item to be laminated into the laminating pouch and then feed it through the machine.
Here's a video that shows how to use it.
Here's a picture of how the TL902 roller tension spring is assembled.
Here's a picture of how the back TL902 older model roller gear is assembled.
Here's a picture of how the back TL902 newer model roller gear is assembled.
Here's a picture of how the front TL902 roller gear is assembled.
Here's a picture of where the TL902 bottom screws go.
Here's a picture of the one TL902 side screw location.
If you need pictures of anything else on the TL902, just ask. Cheers!
I have a part that is from the other side it’s long and has a circle at the bottom can’t remember where it goes
anusharao.p crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 3,649
