Vertical and horizontal lines and flickering section
Hi all,
Recently my 27” Apple Thunderbolt Display has been suffering issues with very brief lines flickering across the screen which I ignored initially. However, it progressed into a more serious issue one day when I started work and there were vertical and horizontal 1 pixel lines (1 of each) and the bottom 1/3 of the screen was flickering and presenting a mirrored image of the top section of the screen.
I booked an appointment with Apple and took it in, only to be told it would be a $1k (AUD) repair for a replacement LCD panel.
I’m just getting a second opinion from you guys.
Obviously I’m not going to pay $1k and can repair it myself. I wondered, should I try replacing the “T-Con” first before the whole panel?
I noticed there’s a few new “E3” panels but they seem to use a 40 pin connector rather than 30 pin so aren’t compatible.
Are the panels from Ali Express (such as this https://www.aliexpress.com/item/LCD-Disp...) any good? The seller reckons it’s a genuine LG panel but you can never tell.
Cheers,
Sam
