The Amazon Echo 2nd Generation was released on October 31, 2017. It is a 5.8" tall Bluetooth smart speaker that features Alexa, a cloud-based voice service that can answer questions and play music.
Temperature reading is 4 to 5 degrees low
Is there a way to adjust the temperature reading on my Echo 2nd Generation Plus.
It reads about 5 degrees low all the time. Can this be tweaked inside, or do I have to mentally add the 4 - 5 degrees when I look at room temp ?
I haven’t found a way - I get the same response, a AC unit nearby is always about 3-7 degrees higher. I’m going to guess the sensor is ‘calibrated’ at the factory and the Echo just reads the results. Besides soldering & replacing the sensor to hopefully fix the temperature setting, I’d call Amazon, I had an excellent experience with their customer support. You other option is to replace the board itself, maybe trading in your broken board to help lower the price of a new one. There’s a take apart here on ifixit on how to replace the subwoofer; You could use those instructions to take the boards out & replace the one you want. That’s another question; Where is the temperature sensor!
Are you talking room temperature? Or outside, outdoor temp?
For room the echo plus 2nd gen has a temp sensor built in, for outside temp it uses a weather service such as weather channel.com
its pulling the weather data from a data provider, as far as I know there is no way to change this at the moment.
Not the echo plus 2nd gen it pulls outside temp from a weather service, however temp in its surrounding s aka room is from q on board sensor just ask what's the temperature in this room , unlike other echo products echo plus 2nd geb xan give you that! :)
Echo plus 2nd gen has a onboarding temp probe, for room temp, pulls data from a service like every other echo for outdoor
Glen Roof crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,727
