In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
Liquid damage/Not charging(says power adapter conncected/no light)
I spilled milk on my laptop (not too much) it shut down on its own. I let it dry over night next day the file and ? screen came up by that after noon it turned on normally. I brought it to the apple store they plugged in something and did a diag test and said nothing was wrong on that. Runs of batter power fine but when it is plugged in the charger light does not come on (tried multiple chargers). When plugged in it says “battery not charging power source: power adapter”
**Images are before and after cleaning**
It’s a blown vcc main rail that reads the battery in when you connect the cable to charge. You’ll need a microsolder technician to diagnose the board and repair the issue
Your images are not sharp enough in detail to see much. It does look like the I/O board got most of the damage (bottom part of image) MacBook Air 13" (Mid 2013-2017) I/O Board and its cable MacBook Air 13" (Mid 2013-2017) I/O Board Cable. I would replace both.
crwdns2886500:0Replace an I/O Board Cable compatible with the Mid 2013 to 2017 13" MacBook Air laptop. Fix the connection between the I/O Board and the Logic Board.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$14.99
crwdns2886500:0Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.crwdne2886500:0
$79.99
Gabrielle Morales crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 101
