Prohibited symbol on boot
I purchased a used Late 2012 i7 with 16 GB of RAM & a 2.25 TB Fusion Drive that was running High Sierra,
The computer seem to be working fine, until just before Christmas it booted once and I got the prohibited symbol. I had not yet moved things over to it so I did not loose much. I rebooted into recovery and reinstalled the OS.
It worked fine for a few days then it happened again. I ran disk utility in recovery mode then disk first aide without much progress. I reinstalled the OS through Disk Utility and 6 hours later I was running again but hesitant to use this machine as a main hub for photos and my iTunes library now that I have had 2 crashes in a few days.
I have searched the web with little to show for it.
I ran Ertchecker and came up with the some results however my post has been deleted 3 times already and i think that is why.
Is the drive failing or is there something else? RAM? The SATA Cable to the drive?
I also saw on this: Upgrading from HDD to SDD, but get prohibitory symbol when booting up?. Is this possible?
I thought It might be my 2TB mechanical drive was starting to fail but searches on the internet came up with nothing.
I now see looking back through one of my RAM chips was not seated correctly or is starting to fail. I know when I got the computer when I ran system profile that the I had 16 GB of RAM. If one ram chip was not seated would it boot at all?
crwdns2944067:04crwdne2944067:0
Do you have an external Time Machine backup. What two drives constitute your set up?
crwdns2934271:0crwdnd2934271:0 mayer crwdne2934271:0
I transferred your other info over from the closed question. The system won't allow URL postings with new members which is why it kept getting deleted.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
The MacBook link doesn't apply here.
There is no time machine backup of this computer yet. I was waiting to move my iTunes Library and Aperture Library to this computer from an external drive and then use the drive as a time machine back up. There is a 250 GB SSD and 2 TB HDD set up as a Fusion Drive. That is the drive you can see referenced in the document attached above.
Note: thanks Dan for helping move stuff around.
crwdns2934271:0crwdnd2934271:0 Matt crwdne2934271:0
