How to identify which machines gray system installation disks are for?
I have about 20 different gray Macintosh system installation disks that I have acquired over the years. I only marked a few of them with the matching machine identification. Doing a web search for the 2Z691-xxxx-x numbers on the disks gives very little information. Does anyone know where to find a list of which disks work with which machines?
Would something like Mactracker http://mactracker.ca/faq.html work for that?
I wasn't able to find any info on Mactracker. I also have a pretty decent "collection" of these disks, yet I have no way of determining what system they are for.
You wouldn't be talking about these ones, I presume?
I have added this post somewhere else to answer this.
AHT and OSX Version Numbers
Original Source
http://hi.baidu.com/gzalanwong/blog/item...
Products Affected Intel iMac
iMac (Late 2009)
Model MB950xx/A IMAC 21.5"/3.06/2X2GB/500GB/9400M
Model MC413xx/A IMAC 21.5"/3.06/2X2GB/1TB/4670-256MB
Model MB952xx/A IMAC 27"/3.06/2X2GB/1TB/4670-256MB
Model MB953xx/A IMAC 27"/2.66QC/2X2GB/1TB/4850-512MB
For Mac OS X 10.6.1, Build 10A2155
Part number Description
2Z691-6588 DVD iMac (21.5-/27-Inch) Install 10.6.1 (Late 09) International
2Z691-6589 DVD iMac (21.5-/27-Inch) Applications Install (Late 09) International
For Mac OS X 10.6.2, Build 10C2234
2Z691-6590 DVD iMac (27-Inch, Quad Core) Install 10.6.2 (Late 09) International
2Z691-6591 DVD iMac (27-Inch, Quad Core) Applications Install (Late 09)
iMac (Mid 2009)
Model MC015xx/A 20"/2.0/2X1GB/160GB/SD/MSE/KB
For Mac OS X 10.5.6, Build 9G556
2Z691-6362 DVD iMac Education OS X Install (Mid 09) International
2Z691-6363 DVD iMac Education Applications Install (Mid 09) International
For Mac OS X 10.6, Build 10A432
2Z691-6540 DVD iMac Education OS X Install 10.6 (Sep. 09) International
2Z691-6545 DVD iMac Applications Install (Sep. 09) International
iMac (Early 2009)
Model MB417xx/A IMAC 20"/2.66/2GB/320/SD/MSE/KB
Model MC019xx/A IMAC 20"/2.66/2GB/320/SD/WLMKB
Model MB418xx/A IMAC 24"/2.66/4GB/640/SD/MSE/KB
Model MB419xx/A IMAC 24"/2.93/4GB/640/256/SD/MSE/KB
Model MB420xx/A IMAC 24"/3.06/4GB/1TB/512/SD/MSE/KB
Model MC020xx/A IMAC 24"/2.66/4GB/640/SD/WLMKB
Model MC021xx/A IMAC 24"/2.93/4GB/640/256/SD/WLMKB
Model MC022xx/A IMAC 24"/3.06/4GB/1TB/512/SD/WLMKB
For Mac OS X 10.5.6, Build 9G3610
2Z691-6436 DVD iMac OS X Install 1 of 2 (Late March 09) International
2Z691-6376 DVD iMac (20-/24-inch) Applications Install (Early 09) International
For Mac OS X 10.5.6, Build 9G2030
2Z691-6230 DVD iMac Install 10.5.6
2Z691-6231 DVD iMac Applications Install
For Mac OS X 10.6 10A432
2Z691-6539 DVD iMac (20-/24-inch) Install 10.6 (Mid 09) International
2Z691-6544 DVD iMac (20-/24-inch) Applications Install (Mid 09) International
iMac (Early 2008)
Model MB323xx/A iMac 20-inch D2.4G/1G/250/SD-DL
Model MB324xx/A iMac 20-inch D2.66/2G/320/SD-DL
Model MB325xx/A iMac 24-inch D 2.8/2G/320/SD-DL
For Mac OS X 10.5.2, Build 9C2028
2Z691-6208 DVD, Install DVD 1, iMac(Very Early 08)-International
2Z691-6195 DVD, Install DVD 2, Mac Pro/MB Pro/MB Air/MB (Early 08)/Mac mini/iMac
For Mac OS X 10.5.4, Build 9E25
2Z691-6248 DVD, Install DVD 1, All Macs Except Mac Pro/Xserve(Early 08)-International
2Z691-6249 DVD, Install DVD 2, All Macs Except Xserve(Early 08)-International
iMac (Mid 2007)
Model MA876xx/A iMac 20-inch D2.0G/1G/250/SD-DL
Model MA877xx/A iMac 20-inch D2.4G/1G/320/SD-DL
Model MA878xx/A iMac 24-inch D2.4G/1G/320/SD-DL
For Mac OS X 10.4.10, Build 8R4031
2Z691-6022 DVD, INSTALL DVD#1,IMAC-International
2Z691-6023 DVD, Install DVD#2-International
For Mac OS X 10.5, Build 9A3129
2Z691-6150 Multi CPU Install DVD1 with 10.5
2Z691-6175 CPU INSTALL DVD 2
iMac (17-inch Late 2006 CD)
Model MA710xx/A iMac 17-inch D1.83G/512/160/Combo
For Mac OS X 10.4.7, Build 8K1106
2Z691-5883 DVD, iMac (Late 2006 17-inch 1.83GHz), Install 1, International
2Z691-5862 DVD, iMac (Late 2006 17-/20-/24-inch), Install 2, International
For Mac OS X 10.4.8, Build 8N1430
2Z691-5967 DVD, MB+MB Pro+Mac Pro, Install 1 of 2, w/10.4.8, V1.2, International
2Z691-5930 DVD, MB+MB Pro+Mac Pro, Install 2 of 2, w/10.4.8, International
iMac (Late 2006)
Model MA590xx/A iMac 17-inch D2.0G/1G/160/SD-D
Model MA589xx/A iMac 20-inch D2.16G/1G/250/SD-DL
2Z691-5859 DVD, iMac (Late 2006 17-/20-inch), Install 1, International
iMac (24-inch)
Model MA456xx/A iMac 24-inch 2.16/1G/250/SD/AP/BT-USA
For Mac OS X 10.4.7, Build 8K1123
2Z691-5861 DVD, iMac (Late 2006 24-inch), Install 1, International
iMac (17-inch Mid 2006)
Model MA406xx/A iMac 17-inch 1.83GHZ Intel Core Duo/512/80/Combo/AP
For Mac OS X 10.4.6, Build 8I2040
2Z691-5734 DVD, iMac, V1.0 Install, 1 of 2, with OS 10.4.6, International
Some discs are printed with "10.4.7" on the label; however the discs actually have 10.4.6.
2Z691-5735 DVD, CPU Install, 2 of 2, with iLife 6.0.2, International
iMac (Early 2006)
Model MA199xx/A iMac 17-inch 1.83GHz Intel Core Duo/512/160/SD/BT/AP
Model MA200xx/A iMac 20-inch 2GHz Intel Core Duo/512/250/SD/BT/AP
For Mac OS X 10.4.4, Build 8G1165
2Z691-5606 SUB ASSY,DVD 1,INST(DL)
2Z691-5607 SUB ASSY,DVD 2,INST(DL)
For Mac OS X 10.4.4, Build 8G1171
2Z691-5736 SUB ASSY,DVD 1,INST(DL)
For Mac OS X 10.4.6
2Z691-5746 SUB ASSY,DVD 1,INST(DL)
2Z691-5796 SUB ASSY,DVD 2,INST(DL)
This is kind of the long way around but the only reliable method I could find was to go to welovemacs and enter the number from the disk. A window would then popup and tell you which machines that disk was good for and if they had it in stock. As I said its not an elegant answer but for only 20 disk doing a few at a time it could work. Good luck on this -- maybe someone else will come up with something more elegant.
So far I've found a couple that way. I was surprised to find how many machines they were good for. It means I have AHT for a lot more machines than I thought. Do you think a guide would be useful?
I certainly do. Go for it.
YEP!
Sure has here...
I find I have one set of new 1.6.7 Snow Leopard discs for a 2011 MBP
Another set of new 10.5 discs Leopard discs for a 2008 iMac
None work with my WMBs or Late 2008 AL 13 Unibody..
Both eBay sellers Refunded my purchase
Told me to keep the discs...
They had only gone by what was on a the boxes
NOT what was on the discs...
A Retail 10.5.2 Updater would not up date 10.4 Tiger to 10.5...
For my 2004 G4/1.33 iBook 14..
I destroyed it... Grrrrrrrr!!!!
So I'm still looking...
Still bidding
On eBay..
mayer crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 6,351
