Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
Is there any speaker replacement guide?
Hey! This is my first post here, and since I couldn’t find guide on how to replace the right speaker of my laptop I figured I could ask in here, thanks in advance for the answers and happy holidays!
A little more info on why I need to repair:
https://www.youtube.com/watch?v=0FI35H6M...
That exactly happened to my laptop when I opened it after I closed it last night. That’s it, didn’t do anything that could’ve caused it and I don’t even have Bootcamp installed (regarding the known Bootcamp speaker bug). I actually never had any issue with this laptop after almost 2 years of using it and this felt like something that was bound to happen eventually given the fact that these new models haven’t been as reliable as the 2015 and before ones.
Anyways, hope I can find some help in here!
Are you sure the speaker is blown? The vid sounds more like a fan bearing issue.
Yes. I'm sure.
To test the speakers open the sound preference control panel then click on the Output tab. There you can bias the output between the speakers using the balance control. Play some music and slide the slide to one side then the other does one side sound off?
Update (12/30/2018)
We currently don’t have a guide but the MacBook Pro 15" Touch Bar Teardown does offer enough details to get to it. Jump down to Step 12 where you can see the speaker is just glued in. Use a heat gun (not to hot!) aimed at the grill where the perforations are so you can soften the glue. Here’s the replacement MacBook Pro 15" Retina (Late 2016-2017) Right Speaker
crwdns2886500:0Replace a right speaker compatible with the Late 2016 to 2017 model A1707 MacBook Pro 15" Touch Bar laptop. Fix issues with sound ouput.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$24.99
I tested before posting, I'm 100% certain my speaker is not working properly anymore.
Thanks a lot, any suggestions on how to adhere the new speaker to the body? can the glue from the removed speaker can be reused if re-heated?
I don't think it would be smart to reuse the glue. I used hot glue to re-attach.
Hi Dan, can you recommend a brand of hot glue? Do the speakers sound the same as the originals? If only one speaker is malfunctioning, is it wise the replace both of the speakers to maintain the same quality left/right? The adhesive seems to be important for the sound quality.
I used Mangocore Black glue sticks. I would just replace the one speaker.
I just finished replacing both speakers in my 2017 Macbook Pro with Touchbar. The procedure isn’t difficult, although in an abundance of caution I spent about half a day to research, prepare, and conduct every step very carefully. Here’s the main discoveries:
  1. It was my first time to open up this Macbook. It’s harder than previous Macbooks. I would definitely recommend a suction cup to create the initial gap in the casing. Then, follow the guides: you have to slide a shim around to the middle side section to cause the clips to detach from the center of the case. I didn’t have to apply any force. The shim itself was wide enough to do the trick. Be careful not to stick it in too far.
  2. I disconnected the battery data cable and power connection. The data cable was straightforward, but the power connection tab required slightly more force than I expected. The hinge on it is metal I believe, so actually you are “opening” (i.e. bending) a metal pivot point—but it is designed for that.
  3. Removing the speaker connectors: this wasn’t included in teh guide. The clip looked like it has a lock tab, but this isn’t true. All you have to do is get under the speaker cable and lift it out. I used the flat end of a spudger in a gentle twisting motion, alternating sides until is came loose. It literally just pops out (lifting up out of the connector casing).
  4. Removing the speakers themselves: These are in fact glued on tightly. Nothing else is holding them on. If you observe closely, espcially if you can compare it to teh new speakers you have ready to iunstall, you’ll notice that the speaker enclosure is custom fit. Every point of contact of the speaker has been glued on. Thus, you can visually trace the edges of the speaker, all around the enclosure. To begin, I inserted the flat, thinnest edge of some tweezers into any noticeable gaps. Don’t force anything, just see if you can get it in. Next, I used a heat gun on lowest setting. I’m sure you can use a hair dryer too, although this may take longer. Apply the heat on the keyboard side of the laptop, sweeping over the narrow area where the speaker is held. Heat it until the laptop metal is warm or almost hot to the touch—not scalding, but approaching pain-threshold level. Then, I paused to let the heat begin to conduct (the glue will take some time to soften). Repeat this 2 or 3 times, allowing time for the glue to soften. When you are ready to try, flip the laptop back over and again insert a flat tip—tweezers worked well for me. Very lightly twist in a few different locations, and see if you get any movement. For me, I detected some movement, but not enough to dislodge the speaker. Thus, I repeated again with the heat gun. Continue doing this until you clear feel the speaker is about ready to come out—like a loose tooth. You will hear popping from the soften glue. Apply heat to any part that’s still stuck—for me, if was usually the lower part of the speaker, closer to where your wrists sit while typing. Now here’s the key: eventually, I created enough gap in the interior side (i.e. nearest the laptop center) of the speaker to get my fingers under it. Then, you can sort of peel it up, so that the proximal side (interior side) of the speaker rises, and eventually the speaker is “on its side”. You will see gobs of glue in varying degrees of attachment. Go ahead and remove the speaker, and clear out the glue. It’s sort of fun to peel.
  5. Installing the new speakers: I took the advice of Miyazaki and used double sided tape. I did just what he suggested. You may want to practice on the old speaker first. Thin double sided tape actually requires some technique, for several reasons. Cutting it smoothly—I ended up using a retractable safety blade/knife. Likewise, for the circular and curved sections of the casing, I did my best to create an exact shape, and tack it on. This was harder than I expected, because it’s tough to exactly match the shape, and also the tape distorts easily. The tape also sticks to your hands. Where possible, don’t remove the second-side tape backing until everything it on. Also, try to make the tape surface seamless. This took me several attempts sometimes to totally remove gaps between tape pieces, but luckily the tape stretches easily (sometimes this is a pain also). You can sort of smoosh out the tape to extend it just enough. Finally, I found that getting tools to help precisely put the tape in place and get it off your fingers is useful. A plastic pencil tip worked well for me—the tape sticks to the plastic less, and using the pencil tip, you can sort of roll the pencil out, which causes less distortion in the tape because it clings a bit less using that technique.
  6. No tricks on attaching the speakers. Just make sure there isn’t much excess tape or it won’t drop back into its enclosure. Attach the speaker cables, the battery power, the battery data, and seal it up. The bottom laptop casing still fits, and will hold the speakers snugly.
  7. Here’s the tape I used: LLPT Double Sided Tape Black Acrylic Strong Mounting Tape 1 Inch x 550 Inch Multiple Sizes > UPDATED <
The speakers sounded great. Also, I did not remove the logic board or anything else. There is no need to do this, but, know your work style. If you aren’t good with precision work, are over-caffeinated, shaking hands, or prone to frustration and breaking things, you may want to remove the logic board. However, this definitely is not necessary. Finally, I’m an insane perfectionist, especially with tape sealing surface area. I’m sure it would work well with less effort.
Good luck everyone!
P.S. I used something like an X-Acto knife as necessary to create my tape shapes. I also used this to precisely and gently remove the tape backing (along with tweezers) once the tape was stuck on and ready. The backing is tough to remove with your fingers if you're dealing with small pieces, and easy to distort.
Can you link the tape you used again? Link of Amazon is dead.
I really loved your post. It's REALLY informative. I'm almost ready to apply your procedure. can you just help me finding the right tape? unfortunately the link is broken. It was a 1mm double tape? I think that the "right" tape thikness is crucial for removing any buzz. did you apply the tape only on the front face of the speaker on even around the edjes? Sorry for the noob questions It's my first attempt! many thanks
Eta crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 4,618
