Do I need 2 RAM upgraded boards for a late 2011 MacBook Pro?
It said a max is 8GB. Only assuming I could get 2 4GB.
All of the Late 2011 models support upto 16 GB of RAM with two SO-DIMM modules. Once we know which model we can tell you a bit more.
I forgot the model number but did go though the entire process to verify everything. Right now it has 2- 2GB boards. I need to increase since it is slow now that it is at High Sierra OS. If I would get 2- 8GB boards that should be more then enough, I would assume
@mwaner2018 - If your system is running slow you might want to backup and reformat your drive. Or, install a SSHD or SSD which will offer faster I/O access which is more likely your issue. Do keep in mind you do want to leave the SD between 1/4 to 1/3 of the drive un-used
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 46
crwdns2942205:01crwdne2942205:0
Which one is yours?
- MacBook Pro 13" (Late 2011)
- MacBook Pro 15" (Late 2011)
- MacBook Pro 17" (Late 2011)
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
