Why iMac Fan Running faster and no display
I have a Late 2013 21.5” iMac i5 2.7 GHz (A1418), I just changed the Hard Disk and RAM Now after changing these I did not see the display while the fan is running very fast.
Would anyone suggest me what should i do now ?
Thanks in advance
First we need to know your exact machine. There are 16 models of the A1418, going from 2012 to 2017.
Look on the bottom of your stand and get the serial number and plug it in here, then then tell us what you have https://everymac.com/ultimate-mac-lookup...
The fan issue is most likely the temperature sensor on Apples proprietary drives and we’ll work on that when I know your model.
Meanwhile, the RAM (tell us exactly what you put in and how much). Don’t change it back to the original state until you give us your exact machine.
It’s always best to do one upgrade at a time and test before going to the next upgrade, just in case you have issues.
UPDATE
To stop the run away fan issue, you will need an
OWC HDD Compatibility for all Apple iMac 27" models 2012 and Later - digital sensor for SMC
https://eshop.macsales.com/shop/imacdiy/...
Now tell me what you did on the RAM and what you put in.
RAM Type:PC3-12800 DDR3*Min. RAM Speed:1600 MHz
Standard RAM:8 GBMaximum RAM:16 GB*
Details:*By default, this system has 8 GB of 1600 MHz DDR3 SDRAM. Apple does not intend for one to upgrade the RAM in this system. This system has two SO-DIMM slots (204-pin).
UPDATE 2
LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Check your connections, hook up to an external monitor to verify signal.
iMac "Core i5" 2.7 21.5-Inch (Late 2013) 2.7 GHz Core i5 (I5-4570R) i have this one
i install 16 GB RAM, while i also apply SMC but i did not see the display while the fan is nosiy
NO. Tell me EXACTLY what RAM you put in. Like PC3-12800 DDR3. What brand? What are the numbers on it?
i have 8G DDR3L 1600
And the forth light is not working also
The fans' job is to cool the interior of your Mac so you want them to run if the interior is hot. To resolve the issue, reset the SMC. Maybe because of too hot its not showing anything.
Kashif Khan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 867
