Whirlpool top load cabrio washer w10612644. No power and lid locked
Washing machine wont come on after power surge. The lid is also locked. What could be wrong and how do I unlock the lid manually?
What happened with this?
First unplug the machine for five minutes to allow it to reset. This failing, please tell us of any error codes you may be getting nowUpdate
since you got a power surge, check the
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
Incoming Power Problem
The electrical outlet may not be getting power. To determine if the outlet is getting power, try plugging something else into the outlet. If the outlet is not getting power, check the home circuit breakers or fuses.
This failed. I've got no error codes. The display is just blank like it's not getting power. I've checked the plug also good.
Question is How to unlock it manually?
You will most likely find the answer to this in your User Manual.
Toni T Millwood crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,613
