Card locked can not take photo
When I boot up my camera the screen displays “card locked” and the camera will not take pictures. Any ideas?
You likely need to flip the “lock” switch. If flipping the lock switch to the unlocked position doesn’t work then you are going to be out of luck.
This usually means the memory card has failed to the extent it can no longer read, but permanently locks into read-only mode. This is HOW you want your card to fail; performance will probably take a hit but you can still pull your files off. It's a protection measure built into flash memory.
Pull your files off of the card and try formatting it in your camera. If it works, use the card until you can replace it but don’t keep using it. If you do, there’s a descent chance the card will die for good and it may not die gracefully to the extent your data is safe. Cards are cheap; data recovery isn’t.
how to solb my problum
crwdns2942667:0crwdne2942667:0 2,001
Thanks much. This solved my problem. I would have never thought of this solution.
crwdns2934271:0crwdnd2934271:0 Richard Asbach crwdne2934271:0
how to solbe my problem
crwdns2934271:0crwdnd2934271:0 bulbulmishra13589 crwdne2934271:0
